Vroege begin Daylight Savings Time/mogelijke problemen
International fliers could get clocked by early jump to daylight savings time
This year's earlier-than-usual arrival of daylight savings time in the USA could spell trouble for travelers flying on international routes, The Wall Street Journal (subscription required) reports. The paper writes that "thanks to an impending disconnect between European and U.S. clocks, cross-continental fliers whose trips entail connections within or beyond the U.S. may find it harder to get a convenient connection and may need to schedule long layovers... "
For example, the Journal cites connections on American Airlines for passengers traveling from Madrid through Miami. The Madrid flight typically lands in Miami at 3:05 p.m. local time, but -– with the USA’s early jump ahead -– it will temporarily land at 4:05 p.m. local time until Europe also springs its clocks forward. For fliers, that makes catching the 4:35 p.m. flight to Houston –- usually not a problem -– all but impossible. Another tight connection looms for Madrid travelers hoping to connect to to Bogota, Colombia, on AA's 5:20 p.m. flight. The usual 2-hour layover on that route now gets whittled down to about an hour.
"So," the Journal asks, "why can't U.S. airlines simply move up the departure time of their flights originating in Europe, ensuring that passengers can get better connections?" The paper notes that doing so "is difficult because of strict 'use it or lose it' rules regarding time slots at European airports. U.S. airlines have little flexibility to adjust their schedules because if they did, they could risk losing control over a valuable time slot at busy hubs, according to the Air Transport Association, a trade organization for U.S. airlines." Similar scheduling problems also exist in Asia, experts say.
How big a problem will air travelers really face once U.S. clocks make their early jump ahead on Sunday? John Hansman, a professor of aeronautics and the head of MIT's International Center for Air Transportation, sums it up like this: "Any change creates some sort of disturbance in the system. How significant is this compared with a snowstorm at JFK? I would say this is not as big of a deal."
Tony de Pony
Volgens Bush is een uurtje langer daglicht goed om het energieverbruik enigszins in te dammen, maar ik denk dat z'n vriendjes liever een uurtje langer op de golfbaan staan.GoBucks schreef:Ik snap ook helemaal niet waar dat 'uurtje verschuiven' voor nodig is
Ik ben er blij mee - zoals de meeste mensen die van surfen houden er blij mee zijn. Door de klok een uur vooruit te hebben gezet draait de aarde nu in 23 uren op z'n as, ipv 24 uren, hetgeen meer frictie tot gevolg heeft.
Meer frictie leidt tot meer wind, dat weer leidt tot hogere golven en betere surfomstandigheden.
Prima zet, die zomertijd in de winter!
"None are more hopelessly enslaved than those who falsely believe they are free."
Marcel
Zuig je dit ter plekke uit je duim of heeft iemand je deze onzin wijs gemaakt?Tony de Pony schreef:Ik ben er blij mee - zoals de meeste mensen die van surfen houden er blij mee zijn. Door de klok een uur vooruit te hebben gezet draait de aarde nu in 23 uren op z'n as, ipv 24 uren, hetgeen meer frictie tot gevolg heeft.
Michigan
Zo zijn wij mensen toch? WIJ vertellen de aarde hoe snel hij mag draaienMarcel schreef:Zuig je dit ter plekke uit je duim of heeft iemand je deze onzin wijs gemaakt?Tony de Pony schreef:Ik ben er blij mee - zoals de meeste mensen die van surfen houden er blij mee zijn. Door de klok een uur vooruit te hebben gezet draait de aarde nu in 23 uren op z'n as, ipv 24 uren, hetgeen meer frictie tot gevolg heeft.
Meer frictie leidt tot meer wind, dat weer leidt tot hogere golven en betere surfomstandigheden.![]()
- Mike
- Petra/VS
- Medebeheerder
:hilarious:
- Jasmino
Dus door onze klok te verzetten gaat de aarde langzamer draaien, of juist sneller????? :oh: :hilarious:
Winston Churchill
Winston Churchill
- markro
- Moderator
Snellerrrrrrrrrrrrrrrrrrrr.Jasmino schreef:Dus door onze klok te verzetten gaat de aarde langzamer draaien, of juist sneller????? :oh: :hilarious:
Heb jij dan niet het gevoel, dat de dagen steeds korter worden?
Je doet steeds meer, in minder tijd, toch heb je steeds tijd tekort en voordat je het weet moet je al weer naar bed.
- Jasmino
Nu dat je het zegt.........ik heb het gevoel dat de tijd steeds sneller voorbij vliegt, dus daaaaaaaaaaar komt dat doormarkro schreef:Snellerrrrrrrrrrrrrrrrrrrr.Jasmino schreef:Dus door onze klok te verzetten gaat de aarde langzamer draaien, of juist sneller????? :oh: :hilarious:
Heb jij dan niet het gevoel, dat de dagen steeds korter worden?![]()
Winston Churchill
Winston Churchill
Oef! Ik dacht altijd dat het lag aan het feit dat ik ouder werd.Jasmino schreef: Nu dat je het zegt.........ik heb het gevoel dat de tijd steeds sneller voorbij vliegt, dus daaaaaaaaaaar komt dat door
- 4316 Weergaves
Laatste bericht door Coyote
- 10 Reacties
- 2622 Weergaves
- 19 Reacties
- 6147 Weergaves
Laatste bericht door Ruud2004
